OpenBuilds
OpenBuilds WorkBee 1050 (40 x 20 in)
Narrow-format lead-screw CNC bundle based on the open-source WorkBee design
Openbuilds has shut down and no longer sells this model, but it remains fully supported in Easel for existing owners. The WorkBee 1050 has a 317 x 762 x 122 mm (12.5 x 30 x 4.8 in) working area and lead screw drive on all axes, based on the open-source WorkBee design by Ooznest’s Ryan Lock. It was sold as a bundle: motors, the BlackBox controller, and a spindle (Dewalt DWP611) were order-time add-ons, not included by default.
The WorkBee 1050 was sold as a bundle: motors, the controller, and a spindle were all order-time options rather than included parts, so its actual RPM and rigidity depend entirely on what the original builder chose. Lead screw drive is a solid base for this narrower footprint, but with motors as an optional add-on, treat this as a lighter-duty machine unless you know your specific build used the 4x NEMA 23 motor option. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Take shallower passes until you know how your build performs. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the OpenBuilds WorkBee 1050 (40 x 20 in). If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The WorkBee 1050 runs GRBL-family firmware (kits built with the optional BlackBox 4X controller run grblHAL, a GRBL-compatible firmware), so it connects directly to Easel over USB. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select ‘Workbee 1050’ in Easel’s machine menu to size the canvas to its 317 x 762 x 122 mm working area.
