SainSmart Genmitsu Genmitsu 1810-PRO
Entry-level DIY CNC kit with a 775 spindle
SainSmart no longer sells this model, but it remains fully supported in Easel. The Genmitsu 1810-PRO has a 180 x 100 x 45 mm effective working area, a 775 spindle (60W rated, up to 9,000 RPM at 36V), and 1.3 A stepper motors (0.25 Nm torque).
The 1810-PRO’s 775 spindle tops out around 9,000 RPM at 36V, below most of the chart. Like most small hobby spindles, it loses torque as it approaches that ceiling, so leave it near the top for everything and control the cut with feed rate instead. If acrylic starts to melt, speed the feed up rather than slowing the spindle, and skip aluminum on this spindle except for light engraving. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. This is a light DIY kit, well short of that bar, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the SainSmart Genmitsu Genmitsu 1810-PRO. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Genmitsu 1810-PRO runs GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Genmitsu 1810-PRO in Easel’s machine menu to size the canvas.
