SainSmart Genmitsu Genmitsu 3018-PROVer V2
Upgraded semi-assembled desktop CNC with a 775 spindle
A SainSmart Genmitsu Genmitsu 3018-PROVer V2 CNC machine.
The Genmitsu 3018-PROVer V2 has a 290 x 180 x 40 mm working area, a 775 spindle (10,000 RPM), and 1.3 A stepper motors on V-slot linear rails.
The 3018-PROVer V2’s 775 spindle runs at a fixed 10,000 RPM, below most of the chart. The spindle speed isn’t adjustable, so leave it at its fixed RPM and control the cut with feed rate instead. If acrylic starts to melt, speed the feed up rather than trying to slow the spindle, and skip aluminum on this spindle except for light engraving. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. This is a light desktop machine on V-slot linear rails with 1.3 A stepper motors, well short of that bar, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the SainSmart Genmitsu Genmitsu 3018-PROVer V2. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Genmitsu 3018-PROVer V2 runs GRBL firmware, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Genmitsu 3018 PROVer V2 in Easel’s machine menu to size the canvas to its 290 x 180 x 40 mm working area.
