SainSmart Genmitsu Genmitsu 3020-PRO MAX V2
CNC router with a 300W spindle for wood and metal
The Genmitsu 3020-PRO MAX V2 has a 300 x 205 x 78 mm working area, a 300W spindle (52mm diameter), and NEMA17 stepper motors (48mm) on a dual steel X-axis guide rail.
The 3020-PRO MAX V2’s 300W spindle doesn’t have a published max RPM, so check the spindle’s plate before assuming it matches the chart. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. An enclosed steel X-axis guide rail gives this machine more stiffness than SainSmart’s smaller kits, but it still isn’t rigid enough for full bit-width depths, so keep passes moderate. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the SainSmart Genmitsu Genmitsu 3020-PRO MAX V2. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Genmitsu 3020-PRO MAX V2 runs GRBL 1.1, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Genmitsu 3020-PRO MAX V2 in Easel’s machine menu to size the canvas.
