SainSmart Genmitsu Genmitsu 3030-PROVer MAX
Precision CNC router with a linear guide and ball screw drive
The Genmitsu 3030-PROVer MAX has a 300 x 300 x 78 mm working area, a 300W spindle (48VDC), and 1.68 A stepper motors (0.45 Nm torque) driving an HG15 linear guide and ball screw.
The 3030-PROVer MAX’s 300W spindle doesn’t have a published max RPM, so check the spindle’s plate before assuming it matches the chart. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, and that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. HG15 linear guides and a ball screw drive put this machine closer to that standard than SainSmart’s lead-screw kits, so you can push somewhat deeper passes, but still watch for chatter rather than assuming full bit-width depth. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the SainSmart Genmitsu Genmitsu 3030-PROVer MAX. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Genmitsu 3030-PROVer MAX runs GRBL 1.1h, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run offline from the machine’s included SD-card controller. Select Genmitsu 3030-PROVer MAX in Easel’s machine menu to size the canvas.
