SainSmart Genmitsu Genmitsu PROVerXL 4x4
Large-format CNC with single or dual Z-axis configurations
The Genmitsu PROVerXL 4x4 is offered in two configurations: Single Z-Axis with a 1300 x 1300 x 118 mm working area, and Dual Z-Axis with a 600 x 1300 x 118 mm working area. Both use a 710W spindle (water-cooled spindle optional) and four closed-loop NEMA23 stepper motors (3.5 Nm torque) on linear guides with ball screws.
The PROVerXL 4x4’s 710W spindle doesn’t have a published max RPM, so check the spindle’s plate before assuming it matches the chart. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, and that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Four closed-loop NEMA23 steppers on HG15/HG20 linear guides with ball screws give this machine real rigidity, but the Single Z-Axis configuration spans a much larger gantry, which flexes more over that distance than the smaller Dual Z-Axis footprint, so favor shallower passes on the larger configuration and use the machine’s own results as your guide either way. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the SainSmart Genmitsu Genmitsu PROVerXL 4x4. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Genmitsu PROVerXL 4x4 runs GRBL 1.1h on a 32-bit board, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Genmitsu PROVerXL 4x4 in Easel’s machine menu, and confirm whether your unit is the Single Z-Axis (1300 x 1300 x 118 mm) or Dual Z-Axis (600 x 1300 x 118 mm) configuration so the canvas is sized to match what your machine can actually cut.
