SainSmart Genmitsu Genmitsu PROVerXL 4030 (6060 Expansion)
PROVerXL 4030 fitted with the 6060 expansion kit
The Genmitsu PROVerXL 4030 (6060 Expansion) pairs a base PROVerXL 4030 with SainSmart’s 6060 XY-Axis Extension Kit and 6060 Hybrid Table to reach a 600 x 600 x 110 mm working area. It uses the base machine’s 300W spindle and NEMA23 stepper motors on a V-wheel rail with lead screws.
The PROVerXL 6060 configuration’s 300W spindle doesn’t have a published max RPM, so check the spindle’s plate before assuming it matches the chart. Depth per pass is where the machine itself matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. This configuration is the base PROVerXL 4030’s NEMA23 steppers and V-wheel rail and lead screw drive stretched over the larger 6060 extension kit’s footprint, which flexes more than the base machine’s smaller working area, so take shallower passes than you would on a standard 4030. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the SainSmart Genmitsu Genmitsu PROVerXL 4030 (6060 Expansion). If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Genmitsu PROVerXL 4030 (6060 Expansion) runs GRBL 1.1h, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Genmitsu PROVerXL 6060 in Easel’s machine menu to size the canvas to the expanded 600 x 600 x 110 mm working area.
