Two Trees
Two Trees TTC450 Ultra
Desktop CNC router with a 500W spindle and dual 12H linear rails
A Two Trees TTC450 Ultra CNC machine.
The TTC450 Ultra is Two Trees’ 460 x 460 x 100mm (18.11 x 18.11 x 3.94 in) desktop router. It ships with a 500W spindle stated to run 8,000 to 30,000 RPM depending on installation, and it rides on dual 12H linear rails for rigidity, controlled by GRBL.
Two Trees states the TTC450 Ultra’s 500W spindle runs 8,000 to 30,000 RPM depending on installation, without a single fixed maximum, so check the plate on the spindle you actually have before you start. Dual linear rails on all axes make this a stiffer machine than a lead-screw desktop router, so it holds a cut better and resists deflection more than a lighter machine would. Depth per pass is still where the machine’s build sets the limit: a truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Work up to deeper passes gradually rather than assuming the machine can take a full-diameter cut right away. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Two Trees TTC450 Ultra. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The TTC450 Ultra runs GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from the machine’s SD card, WiFi, Bluetooth, or touchscreen controls. Select TTC450 Ultra in Easel’s machine menu to size the canvas to its 460 x 460 x 100mm working area.
