Two Trees
Two Trees TTC6050 CNC
Larger-format CNC router with a 500W spindle and ball-screw drive
A Two Trees TTC6050 CNC CNC machine.
The TTC6050 CNC is Two Trees’ largest desktop router, with a 600 x 500 x 100mm (23.6 x 19.6 x 3.9 in) working area. It runs a 500W spindle motor at up to 12,000 RPM, driven by linear guides and ball screws on all three axes.
The TTC6050’s 500W spindle tops out at 12,000 RPM, in range for most of the chart. Ball screws and linear guides on all three axes make this a stiffer machine than a lead-screw desktop router, so it holds a cut better and can push a bit more feed rate before it chatters. Depth per pass is still where the machine’s build sets the limit: a truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Work up to deeper passes gradually rather than assuming the machine can take a full-diameter cut right away. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Two Trees TTC6050 CNC. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The TTC6050 CNC runs GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender, or run it standalone from an SD card via the machine’s built-in touchscreen. Select TTC6050 CNC in Easel’s machine menu to size the canvas.
