VEVOR
VEVOR CNC Router Machine, 120W
Retired entry-level CNC router with a 120W spindle
A VEVOR CNC Router Machine, 120W CNC machine.
Vevor no longer sells this model, but it remains fully supported in Easel. The 120W CNC Router Machine has a 300 x 200 x 72mm (11.81 x 7.87 x 2.83 in) working area and a 120W spindle (75W rated) running at 10,118 RPM. Vevor does not state a stepper motor spec or drive system for this machine.
This spindle is rated at 120W maximum power (75W rated) and runs at 10,118 RPM, below most of the chart. Small spindles like this one lose most of their torque at top speed, so leave it running at its rated speed and control the cut with feed rate instead. Depth per pass is where the machine’s build matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Vevor does not publish a drive system for this machine, and its size and spindle power both point to a light desktop machine, so take shallower passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the VEVOR CNC Router Machine, 120W. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Vevor CNC Router Machine, 120W runs GRBL 1.1, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Vevor CNC Router Machine, 120W in Easel’s machine menu to size the canvas.
