VEVOR
VEVOR 3018 CNC Router Machine, 500W Enhanced
Compact CNC router with a stronger 500W spindle and an extended 80mm Z-axis stroke
A VEVOR 3018 CNC Router Machine, 500W Enhanced CNC machine.
The 3018 CNC Router Machine, 500W Enhanced has a 300 x 180 x 80mm (11.81 x 7.08 x 3.15 in) working area and a 500W spindle rated at 12,000 RPM, with an extended 80mm Z-axis stroke for thicker material. Vevor does not state a stepper motor spec or a drive system for this machine.
This 500W spindle is rated at 12,000 RPM, so treat the chart below as a starting point and cap any recommended speed at 12,000 RPM. Depth per pass is where the machine’s build matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Vevor does not publish a drive system for this machine, so until you know otherwise, treat it as a light-to-mid desktop machine and take shallow passes, especially with the taller Z-axis stroke adding more leverage for the bit to deflect under. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the VEVOR 3018 CNC Router Machine, 500W Enhanced. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Vevor 3018 CNC Router Machine, 500W Enhanced runs GRBL 1.1, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender, or use the machine’s built-in 1.8 in offline controller for standalone jobs. Select Vevor 3018 CNC Router Machine, 500W Enhanced in Easel’s machine menu to size the canvas.
