VEVOR
VEVOR 3018 CNC Router Machine, 60W
Compact entry-level CNC router with a 60W spindle
A VEVOR 3018 CNC Router Machine, 60W CNC machine.
The 3018 CNC Router Machine, 60W has a 300 x 180 x 40mm (11.81 x 7.08 x 1.57 in) working area and a 60W spindle running 11,700 RPM. Vevor does not state a stepper motor spec or drive system for this machine.
This spindle is rated at 60W and runs at 11,700 RPM, below most of the chart. A spindle this small loses most of its torque at top speed, so leave it running at its rated speed and control the cut with feed rate instead. Depth per pass is where the machine’s build matters. A truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. Vevor does not publish a drive system for this machine, and its small footprint and low spindle power both point to a light desktop machine, so take shallow passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the VEVOR 3018 CNC Router Machine, 60W. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The 3018 CNC Router Machine, 60W runs GRBL 1.1 on a 32-bit control board, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender, including the machine’s built-in offline controller. Select 3018 CNC Router Machine, 60W in Easel’s machine menu to size the canvas.
