Whittle CNC
Whittle CNC The WhittleCNC
Compact CNC kit that takes a user-supplied rotary tool
A Whittle CNC The WhittleCNC CNC machine.
THE WhittleCNC is a compact kit CNC, with a 228 x 356 x 50mm (9 x 14 x 2 in) working area, built around a custom stepper shield (EasyDriver drivers) and a CH340 USB connection. It ships without a spindle: an optional ‘With Router’ 110v rotary tool variant is available, or you supply your own compatible rotary tool. Whittle CNC does not state a drive system (belts, screws, or rails) for this machine.
THE WhittleCNC ships without a fixed spindle: you either add the optional 110v rotary tool variant or supply your own compatible rotary tool, so its actual RPM depends on what you install. Check the plate on your own tool before you start, since the chart’s numbers only apply if your tool can actually reach them. Depth per pass is where a light kit machine like this one matters most: a truly rigid machine with a powerful spindle can cut as deep as the bit is wide in a single pass, but that takes real spindle torque, a drive train and clamps that hold firm, a gantry that will not flex, and enough mass to soak up vibration. This machine’s small frame and user-supplied rotary tool put it well short of that bar, so take shallow passes. Push too deep and the bit deflects and chatters, leaving scalloped edges, or it rubs instead of cutting and burns the material. The fastest way to dial in a cut is to see what has already worked for other people.
Worked example for feed rate: 1/8in (3.175mm) two-flute solid carbide end mill in hard wood. The chart says 16,000 RPM. With the bit maker’s 0.025mm per tooth (0.0010 in): 16,000 x 0.025 x 2 = 800 mm/min (31 in/min) feed. For depth per pass, start shallow and check Community Cut Settings in Easel for what works on the Whittle CNC The WhittleCNC. If the cut sounds strained, reduce the depth, not the feed. Slowing the feed below the chip load makes the bit rub instead of cut.
The Whittle CNC Router runs GRBL, so it connects directly to Easel. Install the free Easel Driver and plug in over USB, or connect driverless with Rapid Connect in a Chromium browser (Chrome, Edge, or Opera). Design in the browser, then the Carve button homes, zeroes, and runs the job with live progress. You can also export G-code to run from another sender. Select Whittle CNC Router in Easel’s machine menu to size the canvas.
